Glyph plot for force vector
Is there any option/means to visualize the per-atom force vector as arrow glyphs using Ovito?
It is possible to visualize the glyphs plot for displacement as long as it is computed using the existing Modifiers within Ovito. I was thinking to use the Modifier Compute property to create local per-particle 3D vector variable but it is written in the manual that in the current program version, the modifier does not allow you to create user-defined vector properties. You can only create scalar user-defined properties."
I am wondering if there is any other option to plot the glyph arrow for any vector properties e.g, per-atom force.
Subhendu
Yes, you can use the Compute Property Modifier in OVITO Basic to generate a couple of standard vector properties, e.g. Velocity, Displacement, Force. If you select any of those from the “Output property” drop-down menu, the input expression field will expand and lets you enter a separate math expression for each vector component.
Moreover, if the per-atom forces are part of your input data, the corresponding visual element should be automatically created for you during file import. How does your data format look like?
In OVITO Pro, you’ll have more flexibility creating custom vector properties by using a Python-based modifier function like the following
### Create Custom Vector Property
from ovito.data import *
from ovito.pipeline import ModifierInterface
from ovito.traits import OvitoObject
from traits.trait_types import Str
from ovito.vis import *
import numpy as np
class CreateCustomVectorProperty(ModifierInterface):
    vector_vis = OvitoObject(VectorVis, flat_shading = False, alignment = VectorVis.Alignment.Base)
    title = Str("My vector property", label="Property Name")
    def modify(self, data: DataCollection, **kwargs):
        # Add a new vector property to the particles:
        vector_data = np.random.random_sample(size=(data.particles.count, 3))
        property = data.particles_.create_property(self.title, data=vector_data)
        # Attach the visual element to the output property:
        property.vis = self.vector_vis
        property.vis.title = self.title
Hi Constanze,
Thank you for your input!
Your first suggestion itself works. I misunderstood the writing part in the Vector properties.
I have cfg files that have force data computed due to the boost potential like this:
Number of particles = 7860
A = 1 Angstrom (basic length-scale)
H0(1,1) = 69.5753 A
H0(1,2) = 0 A
H0(1,3) = 0 A
H0(2,1) = 0 A
H0(2,2) = 73.1765 A
H0(2,3) = 0 A
H0(3,1) = 0 A
H0(3,2) = 0 A
H0(3,3) = 17.2444 A
.NO_VELOCITY.
entry_count = 8
auxiliary[0] = id
auxiliary[1] = c_CNA
auxiliary[2] = v_BoostForceX
auxiliary[3] = v_BoostForceY
auxiliary[4] = v_BoostForceZ
Now I am able to visualize the force as glyph plot.
Regards
Subhendu Chakraborty
