Got“Segmentation fault”error when using pair_style reax/c
-I compiled lammps with reax option, when I run my input script I got the error “Segmentation fault”. I used safezone and mincap in pair_style reax/c command in the manual, but it didn’t work.
-I created a box with molten silica and water molecules at 4050K and 3200bar(they had already had a chemical reaction), then I added some new H2O into it, and made a new data file using VMD. When I run the input file, I got “Segmentation fault”.
-The information in slurm file is listed below:
this is useless. we need LAMMPS output, if there is any.
-I’ll be appreciate it if you could help me with the problem.
this is difficult from remote without having access to all files and all info. i suggest you try to run interactively with just one CPU and using the -echo screen flag, so that you can see which command is being executed when the segmentation fault happens. my suspicion would be, that there is a mismatch between the format of the updated data file and the atom style you are using. another possible source of problems could be overlapping atoms due to the added molecules.
