gpu library
I was trying to build gpu library to use it with lammps I got the following messages…
~/Desktop/lammps/src$ sudo ./Make.py -p gpu -gpu mode=single arch=35 -o gpu -a lib-gpu file mpi
Installing packages …
Action lib-gpu …
building gpu library …
File “./Make.py”, line 2302, in
if action.startswith(“lib-”): actions.lib(action[4:])
File “./Make.py”, line 234, in lib
exec(str)
File “”, line 1, in
File “./Make.py”, line 1301, in build
if “shannon” in os.environ.get(“HOST”): make = “srun make”
TypeError: argument of type ‘NoneType’ is not iterable
I think it has to do python…I have python 2.7 installed…
I appreciate any help…
messages...
-a lib-gpu file mpi
Installing packages ...
Action lib-gpu ...
building gpu library ...
File "./Make.py", line 2302, in <module>
if action.startswith("lib-"): actions.lib(action[4:])
File "./Make.py", line 234, in lib
exec(str)
File "<string>", line 1, in <module>
File "./Make.py", line 1301, in build
if "shannon" in os.environ.get("HOST"): make = "srun make"
TypeError: argument of type 'NoneType' is not iterable
I think it has to do python...I have python 2.7 installed....
no. it is sloppy (python) programming in Make.py. :wink:
please try applying the following change to your copy of Make.py
diff --git a/src/Make.py b/src/Make.py
index 81d0c65..8c46cfc 100755
--- a/src/Make.py
+++ b/src/Make.py
@@ -5,7 +5,7 @@
# Syntax: Make.py -h (for help)
# Notes: needs python 2.7 (not Python 3)
-import sys,os,commands,re,copy,subprocess
+import sys,os,commands,re,copy,subprocess,platform
# switch abbrevs
# switch classes = created class for each switch
@@ -1298,7 +1298,7 @@ class GPU:
     # this is b/c Cuda libs are not all available on host
     make = "make"
- if "shannon" in os.environ.get("HOST"): make = "srun make"
+ if "shannon" == platform.node() : make = "srun make"
     commands.getoutput("cd %s; s \-f Makefile\.auto clean&quot; (libdir,make))
     if jmake: str = "cd %s; %s -j d \-f Makefile\.auto&quot; (libdir,make,jmake.n)
you can also try building the conventional way using makefiles directly.
