Hello all,
I am trying to achieve a certain density (rho_desired) of crosslinked epoxy system. My initial system is at lower density (rho_initial ~ 6*rho_desired).
Case 1. I am using change_box command to decrease the box dimensions and achieving denser system. I am observing that instead of decreasing the box size over given “run period”, box size is changing at the start of each “run period”, which means box is changing suddenly.
Case 2. I am using press/berendsen command to apply some guessed hydrostatic pressure to bring the density of the system to rho_desired. This time, density seems to be changing gradually until a certain value, ~1.8*rho_initial. After this, I am observing that density is increasing but is fluctuating too much.
I am using reaxff potential. Following is my input script:
REAX potential for CHON system
units real
atom_style charge
read_data datapress3.txt
pair_style reax/c lmp_control lgvdw yes
pair_coeff * * ffield.reax.EPON H C N O
neighbor 2 bin
neigh_modify every 10 delay 0 check no
timestep 0.01 # 0.25
fix 1 all nve
fix 2 all qeq/reax 1 0.0 10.0 1e-6 param.qeq
fix 3 all temp/berendsen 300.0 300.0 1000.0
reset_timestep 0
T=10 K
fix 5 all nvt temp 300.0 300.0 1000.0
fix 4 all press/berendsen iso 0.0 100.0 1000.0
change_box all x final -14.50 14.50 y final -14.50 14.50 z final -14.50 14.50 remap
thermo 100
thermo_style custom step temp pe etotal press pxx pyy pzz density
dump 2 all custom 100 trypress4.xyz id type x y z
run 100000
write_data datapress4.txt
Please provide some suggestions.
Thanks!,
Rajni Chahal
