Granular simulation: Memory leak & Segmentation fault
Hi list,
I’ve been using the GRANULAR package in LAMMPS to simulate granular flow just fine (both Windows and Linux). Recently I try to simulate annular shear flow, whose boundary control involves converting from Cartesian to Polar coordinates and defining/calculating many intermediate variables.
Now unlike previous jobs, the issue with this job is that it finishes alright on my Windows machine, but on Linux it runs for some time before exhausting all allocated memory and generating error: “slurmstepd: Exceeded job memory limit at some point. srun: error: task 2: Killed”. This looks like a memory leak to me. (LAMMPS 15May2015 version)
Naturally, I then tried it on newer versions (11-Aug17). It seems the memory leak problem is fixed, but weirdly, it only works under 10 processes, and when using more than 10 cores it would get segmentation fault before even starting the execution.
The script included. It would need the file “circular_adapt.data” to run though, which I can attach along if needed. Any input/idea would be appreciated!
Annular Shear
units si
dimension 2
atom_style sphere
boundary p f p
newton off
comm_modify vel yes
variable dl equal 0.003
variable ds equal 0.002
variable err equal 0.1
variable dllower equal {dl}*(1-{err})
variable dlupper equal {dl}*(1+{err})
variable dslower equal {ds}*(1-{err})
variable dsupper equal {ds}*(1+{err})
variable cl equal 0.5
variable cs equal 0.5
variable d equal {cl}*{dl}+{cs}*{ds} # 0.0025
variable width equal 300*$d
variable height equal 500*d variable rhos equal 2450 variable rhol equal {rhos}*{ds}/{dl} # 1633
Define origin point
variable x_orig equal {width}/2.0 # x coordinate of origin variable y_orig equal {x_orig} # y coordinate of origin
read_data circular_adapt.data
neighbor $d bin
neigh_modify delay 0
Interaction model parameters
variable Pwall equal 100 # units N/m
variable Kappa equal 10000.0 # Keep this number above 10000
variable kn equal {Pwall}*{Kappa} # units N/m
variable kt equal {kn}*0.5 variable e equal 0.1 # Restitution coefficient variable ms equal 3.14/6*({ds})^3v_rhos # 1.025710^(-5)
variable ml equal 3.14/6*({dl})^3*v_rhol # 2.3079*10^(-5) variable m equal {cl}{ml}+{cs}${ms} # Average grain mass: 1.666810^(-5)
variable gamman equal -2
ln($e)/(3.14^2+(ln($e))^2)^0.5*(2v_kn/$m)^0.5
variable gammat equal 50
(9.8/$d)^0.5*0
Interaction model
pair_style hybrid/overlay gran/hooke/history {kn} {kt} {gamman} {gammat} 0.4 1 gran/hooke/history {kn} {kt} 0 0 0.4 1 gran/hooke/history 0 0 0 0 0 0
pair_coeff 1 1 gran/hooke/history 1
pair_coeff 1 2 gran/hooke/history 1
pair_coeff 2 2 gran/hooke/history 1
pair_coeff 1 3 gran/hooke/history 2
pair_coeff 2 3 gran/hooke/history 2
pair_coeff 1 4 gran/hooke/history 1
pair_coeff 2 4 gran/hooke/history 1
pair_coeff 3 3* gran/hooke/history 3
pair_coeff 4 4 gran/hooke/history 3
group inside type 1 2
group outbound type 3
group inbound type 4
fix 1 inside nve/sphere
compute stress all stress/atom NULL pair
fix 2 all enforce2d
Convert to polar coordinates
variable r_coord atom sqrt((x-{x_orig})*(x-{x_orig})+(y-{y_orig})*(y-{y_orig}))
variable theta_coord atom atan2((y-{y_orig}),(x-{x_orig}))
variable f_r atom fxcos(v_theta_coord)+fysin(v_theta_coord)
variable f_theta atom fycos(v_theta_coord)-fxsin(v_theta_coord)
Use velocity control method to apply pressure
compute 1 all erotate/sphere
compute R_outer outbound reduce ave v_r_coord # Radius of outer boundary center
compute R_inner inbound reduce ave v_r_coord # Radius of inner boundary center
compute F_rad_reac outbound reduce sum v_f_r # Radial reaction force summation on outer boundary grains (in units N)
variable P_rad_reac equal (c_F_rad_reac)/(2PIc_R_outer) # units N/m
compute F_theta_reac outbound reduce sum v_f_theta # Annular reaction force summation on outer boundary grains (in units N)
variable S equal (c_F_theta_reacc_R_outer)/(2PIc_R_innerc_R_inner) # units N/m
variable mu_wall equal v_S/v_P_rad_reac
variable gres equal sqrt(m*v_kn)*100 # gp as before variable Vr equal (v_P_rad_reac-{Pwall})(2PI*c_R_outer)/${gres} # Radial velocity with which outer boundary grains should all move
Convert radial velocity back to atom-wise x and y velocities
variable V_x atom v_Vrcos(v_theta_coord)
variable V_y atom v_Vr
sin(v_theta_coord)
Move the outer boundary
fix 3 outbound move variable NULL NULL NULL v_V_x v_V_y NULL
thermo_style custom step atoms ke vol c_1 c_R_inner c_R_outer c_F_rad_reac v_P_rad_reac v_Vr c_F_theta_reac v_S v_mu_wall # output equal/vector-style variables
thermo 100000
thermo_modify lost error norm no
compute_modify thermo_temp dynamic yes
Output setting
dump 1 all custom 100000 output-shear-*.txt id type x y z vx vy vz fx fy fz v_r_coord v_theta_coord v_f_r v_f_theta v_V_x v_V_y diameter c_stress[1] c_stress[2] c_stress[3] c_stress[4] c_stress[5] c_stress[6]
dump 2 all image 10000000 image.*.jpg type diameter &
zoom 1.8 size 600 1024
dump_modify 2 pad 5 backcolor white
dump 3 all movie 500000 movie.mpg type diameter &
dump_modify 3 pad 5 backcolor white
Set timestep
variable tauc equal (3.14^2+(ln($e))^2)^0.5*(m/4/v_kn)^0.5 # 7.9485^(-6) timestep (v_tauc*0.03)
Let the system relax
run 0
Start rotating the inner boundary
variable Vwall_tilde equal 0.01 # dimensionless wall velocity
variable Vwall equal {Vwall_tilde}*c_R_inner*sqrt({Pwall}/m) # dimensional wall velocity 367.4*0.01=3.674(m/s) variable Twall equal (2*PI*c_R_inner)/{Vwall} # period of inner wall rotation (units s)
fix 4 inbound move rotate {x_orig} {y_orig} 0 0 0 1 ${Twall}
run 100000000
write_restart shearing-*.restart
Hi list,
I've been using the GRANULAR package in LAMMPS to simulate granular flow
exhausting all allocated memory and generating error: "slurmstepd:
Exceeded job memory limit at some point. srun: error: task 2: Killed". This
​that version is not "new enough". if you want somebody to seriously look
into it, you have to check against the very latest version (11 May 2018).
LAMMPS is a large code and there are bugfixes and improvements applied all
the time. before somebody is going to spend the time researching and
testing for a potential bug, other options have to be exhausted first.​
The script included. It would need the file "circular_adapt.data" to run
appreciated!
​please try to construct a "minimal" data file, and provide it here (best
compressed with gzip). the smaller the data file that reproduces the
segfault, the easier it is to debug the issue.
axel.​
