Graphene stress-strain curve
I am simulating graphene 50*11 Ang. under tensile using airebo force field.
After simulation stress-strain curve give an ultimate strain in 0.4 at 210 Gpa stress. It is more strange rather than what others found before.
I found the Ultimate strain from 0.12 to 0.22 in other references.
my input file is as follow: (Could you please help me in this issue?)
------------------------ INITIALIZATION ----------------------------
atom_style atomic
newton on
----------------------- ATOM DEFINITION ----------------------------
read_data data.grap.txt
mass 1 12.000
------------------------ FORCE FIELDS ------------------------------
pair_style airebo 3.0
pair_coeff * * CH.airebo C
------------------------- SETTINGS ---------------------------------
#-------------system equilibrium before deformation-------------------
reset_timestep 0
timestep 0.001
fix 1 all npt temp 300 300 2 iso 0 0 1 drag 1
thermo 1000
thermo_style custom step lx ly pxx pyy press pe temp
##-------------Running relaxation------------------
run 20000
unfix 1
#---- Final length at z direction----
Store final cell length for strain calculations
variable tmp equal “ly”
variable L0 equal {tmp} print "Initial Length, L0: {L0}"
Check your reference point (0 strain, 0 stress) when plotting your Stress-Strain Curve.
Dear Xiaolin,
My reference point does not have any problem. I heard that after each iteration or dynamic run I should allow the system to be relaxed!
But I do not know how I have to do this deal.
I will appreciate everybody help me in this issue.
B. regards
Amir
