Hello everyone,
i'm trying to simulate CO2-molecules, but I receive the following
error message:
APPLICATION TERMINATED WITH THE EXIT STRING: Hangup (signal 1)
At first I thought that the pppm-style charge distribution represented
the problem, but no changes there helped. Even if I omit charges
completely, the problem persists.
I checked the mailing list and found only one entry about this
problem, considering a too large cutoff radius, which shouldn't be the
problem in my case.
I'm currently at a loss to determine the origin of this failure and I
would appreciate any help or hint, where to look!
Thank you for your time and help in advance,
Jan
The input for read_data is attached and the setup is:
in.co2:
# 512 CO2 in a 3d-box
units real
atom_style hybrid angle charge
pair_style lj/cut/coul/long 21.0 21.0
bond_style harmonic
angle_style harmonic
kspace_style pppm 1.0e-4
atom_modify map array sort 1000 0
read_data data.co2zhang
group co2 molecule <= 512
group Cs type 1
pair_coeff 1 1 0.0573209 2.7918 21.0
pair_coeff 2 2 0.164254 3.0 21.0
pair_modify table 12 mix arithmetic
neighbor 3.0 bin
neigh_modify exclude molecule co2
velocity co2 create 290.0 12345 dist gaussian mom yes
fix 1 co2 shake 0.00001 20 1000 b 1 t 1 2
fix 1 all nvt temp 290.0 290.0 100.0
timestep 1
compute clusterdef Cs cluster/atom 6.3728
thermo_style multi
thermo 1000
dump 1000 all custom 1000 dump.co2 id type x y z c_clusterdef
run 10000
data.co2zhang (68.6 KB)
