Dear LAMMPS users
I simulated a box of 2000 water molecules in vacuum space and made a vapor-liquid interface. After simulation,I used hbond/dreiding/lj command with rerun dump files to calculate number of hbonds and hbond energy.
Here is my input file and the results. As there is no example of using this pair_style with rerun command, I will appreciate if anyone can give me suggestions about correctness of this way of hbonds calculation.
Dear LAMMPS users
please note, that this mailing list is not an input file verification or
approval service.
if you want to confirm that a feature in LAMMPS works as expected (like you
should, even *if* there are examples provided), you can simply construct an
input deck for a test system, that is so simple/small, that you can compute
the result that you should see manually by yourself.
Thank you axel.
I see, you’r right. I apologizes that my question was not correct and vague.
My question was about the form which I used, to extract results, not the correctness of the results. I know I should valid my results with literature but I read a comment of you about using hbond/dreiding pair style for extracting hbond results and I want to know that I stepped in the right way or not?
Thank you for your consideration
Thank you axel.
I see, you'r right. I apologizes that my question was not correct and
vague.
right way or not?
this is the same thing, and thus i have to repeat:
approval service.
read the documentation and make tests.
whether you reproduce results from literature doesn't apply here. that is
something for confirming specific choices of parameters to represent
specific properties of a given system.
