Help for using dump molfile
I’m trying to use dump molfile command, but it doens’t works.
the command I’m trying to use is
dump 1 all molfile 1000 test.pdb pdb
and the error message is
ERROR on proc 0: No suitable molfile plugin found (…/dump_molfile.cpp:105)
I’m using vmd 1.9.3 and it works well alone.
I compiled lammps with yes-user-molfile, and there is no error in compiling and using other commands. ( I didn’t change /lib/molfile/Makefile.lammps )
I tried to assign plugin path in dump command (dump 1 all molfile 1000 test.pdb pdb .:/usr/local/lib/plugins/vmd/plugins/LINUXAMD64/molfile ) but it doens’t work.
I also copied the files in /usr/local/lib/plugins/vmd/plugins/LINUXAMD64/molfile were copied to working directory but it doens’t work too.
(The files in /usr/local/lib/plugins/vmd/plugins/LINUXAMD64/molfile is as follows:
abinitplugin.so brixplugin.so dcdplugin.so fs4plugin.so jsplugin.so molemeshplugin.so pbeqplugin.so psfplugin.so uhbdplugin.so vaspxmlplugin.so
avsplugin.so carplugin.so dlpolyplugin.so gamessplugin.so lammpsplugin.so msmsplugin.so pdbplugin.so raster3dplugin.so vasp5xdatcarplugin.so vtfplugin.so
babelplugin.so ccp4plugin.so dmsplugin.so graspplugin.so maeffplugin.so namdbinplugin.so pdbxplugin.so rst7plugin.so vaspchgcarplugin.so vtkplugin.so
basissetplugin.so corplugin.so dsn6plugin.so grdplugin.so mapplugin.so netcdfplugin.so phiplugin.so situsplugin.so vaspoutcarplugin.so webpdbplugin.so
bgfplugin.so cpmdplugin.so dtrplugin.so gridplugin.so mdfplugin.so offplugin.so pltplugin.so spiderplugin.so vaspparchgplugin.so xbgfplugin.so
binposplugin.so crdplugin.so dxplugin.so gromacsplugin.so mol2plugin.so parm7plugin.so plyplugin.so stlplugin.so vaspposcarplugin.so xsfplugin.so
biomoccaplugin.so cubeplugin.so edmplugin.so hoomdplugin.so moldenplugin.so parmplugin.so pqrplugin.so tinkerplugin.so vaspxdatcarplugin.so xyzplugin.so
I also tried to change /lib/molfile/Makefile.lammps as
molfile_SYSINC = /usr/local/lib/vmd/plugins/include/molfile_plugin.h
molfile_SYSPATH = -Ldir
and it compiles well, but the command doesn’t work again.
I’m not good at linux, so I couldn’t figure it out what causes the error, vmd plugins or lammps.
Could you tell me what is the problem?
I really look forward to your reply.
Kihoon Bang.
