Help-NEB-Reaxff
Hello lammps-users,
I am running NEB calculations with Reaxff on hydrocarbons cracking in zeolites. I obtained the Rexff parameters from dr. Adri van Duin. However, my Neb calculations never seem to converge even after 3000 steps. I am using the following script:
atom_style charge
atom_modify map array
atom_modify sort 0 0.0
read_data /rdsgpfs/general/user/za1417/home/WORK/Fau_AlH/NEB/Fau_LAMMPSNEB_ASE/data_initial
interactions
pair_style reax/c NULL
pair_coeff * * ffield.reax Al Si O H C
mass 1 26.981538
mass 2 12.011000
mass 3 1.008000
mass 4 15.999000
mass 5 28.085000
run
variable i equal part
fix fix_nve all nve
fix 1 all qeq/reax 1 0.0 10.0 1e-6 reax/c
group nebatoms id 145:156
group nonneb subtract all nebatoms
fix 2 nebatoms neb 1.0 parallel ideal
fix 3 nonneb setforce 0 0 0
dump dump_all all xyz 100 neb$i.xyz
thermo 10
timestep 0.001
min_style fire
neb 0.0 0.01 3000 1500 50 final final.coord
print “end_of_lammps
Is there anything that I could improve? or is it that NEB doesn’t work very well with Reaxff. Is there any other method to calculate reaction barriers?
Best Regards,
this is very difficult to debug from remote. have you checked that you can complete a run of a simple minimization for this system. what are the remaining forces?
please note, that by using fix setforce, your system’s forces are no longer consistent with the energies. so if the part of the system where the forces are set to zero are not properly relaxed, it might confuse the minimizer by resulting in energy changes that do not correspond with the forces based displacements.
