I’ve been playing a bit with the Wien2k parser, with mixed success.
My first question is how to treat variables which are printed every scf iteration but are mostly interesting just in the last, such as the total energy.
So far what I have done is to add helper variable:
self.totE = 0 (in initialize_values)
and I save the value after every scf iteration in onClose_section_scf_iteration:
and later add it to backend in onClose_section_single_configuration_calculation
backend.addValue(“energy_total”, self.totE)
however this feels like a lot of unnecessary copies and code.
For example the current Wien2k parser has code like this:
def onClose_section_system
# atom force
atom_force = []
for i in [‘x’, ‘y’, ‘z’]:
api = section[‘x_wien2k_for_’ + i]
if api is not None:
atom_force.append(api)
This doesn’t works since section is empty, as there is no ‘x_wien2k_for_x’ in section inside onClose_section_system (its accessible only in onClose_section_scf_iteration) so api is always None and the atom_force belongs to section_single_configuration_calculation anyway. However if one could do it like this it would simplify stuff somehow. So I wonder what the original intent of the author was? So is it possible to somehow access the variables parsed in different section in onClose of another section?
I feel this is somehow related to the caching concept which I don’t get at all, but maybe this is completely unrelated.
What I also don’t understand is how are the repeating variables treated: for example when parsing some repeating stuff (inside section_scf_iteration) using something similar to this example line:
SM(r"ATOM[0-9]+\s*(?P<x_wien2k_force>[-+0-9.]+)", repeats = True),
it will match several lines and when I do
print(section[‘x_wien2k_force’]) in onClose_section_scf_iteration
it will show correctly an array with all the values for all matched atoms. But later when looking at output of “nomad parse --show-archive” there is only the last value, the rest was lost somewhere along the way. How to make the array actually propagated into the archive?
Any help would be appreciated.
Best regards
Pavel
