Hi, all:
I am new to the LAMMPS. I need some help to set up file for liquid
simulation. My target is methanol (CH3OH). Here is my questions:
1) how do I make more methanol molecules in a box instead of just one? I
tried replicate command and got some extra bonds between molecules.
how do you determine this? replicate only replicates bond information. it
doesn't add bonds.
Yes, you are right. Once I enlarge the box, the extra bonds got away.
2) I want each molecule has a random velocity before simulation. The
velocity command acts on a group of atoms not molecules. If I use the
velocity command, the atoms in each molecule will move randomly and gave
a wrong molecular configuration (e.g. the H and C atoms of CH3 will be
on the same plane).
this has nothing to do with the velocity initialization, but more likely with
incorrect assignment of bonded interactions.
Here is my data file:
LAMMPS data file. CGCMM style. atom_style full generated by VMD/TopoTools v1.1 on Mon May 16
6 atoms
5 bonds
7 angles
3 dihedrals
0 impropers
4 atom types
3 bond types
3 angle types
1 dihedral types
0 improper types
-10.00000 10.00000 xlo xhi
-10.00000 10.00000 ylo yhi
-10.00000 10.00000 zlo zhi
Pair Coeffs
1 0.207 3.775 #CH3
2 0.0 0.0 #HC
3 0.17 3.07 #OH
4 0.0 0.0 #HO
Bond Coeffs
1 320.0 1.406 #CT-OH
2 340.0 1.108 #CT-HC
3 553.0 0.955 #HO-OH
Angle Coeffs
1 55.0 107.56 #CT-OH-HO
2 50.0 107.09 #H1-CT-OH
3 35.0 106.51 #HC-CT-HC
Dihedral Coeffs
1 0.5 1 0 #x-CT-OH-X
Masses
1 12.010700 # C
2 1.007940 # HC
3 15.999400 # O
4 1.007940 # HO
Atoms
1 1 1 0.265000 -5.691000 0.880000 -0.007000 # C LIG
2 1 3 -0.700000 -4.275000 0.885000 0.007000 # O LIG
3 1 2 0.000000 -6.060000 1.908000 -0.008000 # H LIG
4 1 2 0.000000 -6.063000 0.348000 0.871000 # H LIG
5 1 2 0.000000 -6.035000 0.371000 -0.911000 # H LIG
6 1 4 0.435000 -4.000000 1.343000 0.820000 # H LIG
Bonds
1 1 1 2
2 2 1 3
3 2 1 4
4 2 1 5
5 3 2 6
Angles
1 2 2 1 3
2 2 2 1 4
3 2 2 1 5
4 3 3 1 4
5 3 3 1 5
6 3 4 1 5
7 1 1 2 6
Dihedrals
1 1 3 1 2 6
2 1 4 1 2 6
3 1 5 1 2 6
Here goes the input file:
# Methanol
units lj
atom_style full
pair_style lj/cut/coul/cut 10.0 10.0
bond_style harmonic
angle_style harmonic
dihedral_style harmonic
read_data data.methanol
#replicate 2 2 2
velocity all create 300.0 3457567 dist uniform
thermo_style multi
thermo 50
fix 1 all nvt temp 275.0 275.0 100.0 tchain 1
dump 1 all atom 1 dump.methanol
run 300
And the dump file for the first 10 time steps, step 5 shows the CH3 is almost on the same plane:
ITEM: TIMESTEP
0
ITEM: NUMBER OF ATOMS
6
ITEM: BOX BOUNDS pp pp pp
-10 10
ITEM: ATOMS id type xs ys zs
1 1 0.21545 0.544 0.49965
2 3 0.28625 0.54425 0.50035
3 2 0.197 0.5954 0.4996
4 2 0.19685 0.5174 0.54355
5 2 0.19825 0.51855 0.45445
6 4 0.3 0.56715 0.541
ITEM: TIMESTEP
1
6
-10 10
1 1 0.214356 0.544182 0.498901
2 3 0.286135 0.543621 0.499653
3 2 0.203019 0.595869 0.505436
4 2 0.198096 0.516946 0.549958
5 2 0.199867 0.52017 0.455105
6 4 0.305985 0.57333 0.548086
ITEM: TIMESTEP
2
6
-10 10
1 1 0.213267 0.544362 0.498164
2 3 0.286026 0.543001 0.498973
3 2 0.209014 0.59637 0.511259
4 2 0.199354 0.516519 0.556291
5 2 0.201454 0.521771 0.455713
6 4 0.311854 0.579343 0.554898
ITEM: TIMESTEP
3
6
-10 10
1 1 0.212187 0.544538 0.497452
2 3 0.285929 0.542402 0.498325
3 2 0.214973 0.596905 0.51705
4 2 0.200635 0.51615 0.562455
5 2 0.202991 0.52334 0.456236
6 4 0.317482 0.585026 0.561202
ITEM: TIMESTEP
4
6
-10 10
1 1 0.211117 0.544711 0.496779
2 3 0.285852 0.541833 0.49772
3 2 0.220889 0.597453 0.522784
4 2 0.201939 0.515861 0.568352
5 2 0.204471 0.52487 0.456634
6 4 0.32274 0.59022 0.566784
ITEM: TIMESTEP
5
6
-10 10
1 1 0.210062 0.544883 0.49616
2 3 0.285802 0.541302 0.497171
3 2 0.226751 0.597976 0.528425
4 2 0.203262 0.515677 0.573885
5 2 0.205899 0.526348 0.456874
6 4 0.327505 0.594776 0.571457
ITEM: TIMESTEP
6
6
-10 10
1 1 0.209022 0.545059 0.49561
2 3 0.285785 0.540818 0.496687
3 2 0.232539 0.598423 0.53393
4 2 0.204593 0.515616 0.57896
5 2 0.207291 0.527761 0.456927
6 4 0.331663 0.598565 0.575062
ITEM: TIMESTEP
7
6
-10 10
1 1 0.208002 0.545243 0.495141
2 3 0.285805 0.540388 0.496276
3 2 0.238216 0.598736 0.539247
4 2 0.20592 0.515696 0.583492
5 2 0.208667 0.529093 0.456778
6 4 0.335115 0.601474 0.577473
ITEM: TIMESTEP
8
6
-10 10
1 1 0.207007 0.54544 0.494766
2 3 0.285867 0.540017 0.495943
3 2 0.243734 0.598857 0.544321
4 2 0.207229 0.51593 0.587402
5 2 0.210044 0.530329 0.456417
6 4 0.337779 0.603418 0.5786
ITEM: TIMESTEP
9
6
-10 10
1 1 0.206044 0.545654 0.494497
2 3 0.285974 0.539709 0.495692
3 2 0.249031 0.598739 0.54909
4 2 0.208503 0.516328 0.590625
5 2 0.211436 0.531458 0.455844
6 4 0.339597 0.604339 0.578392
ITEM: TIMESTEP
10
6
-10 10
1 1 0.205121 0.545888 0.494341
2 3 0.286126 0.539467 0.495522
3 2 0.254041 0.59834 0.553492
4 2 0.209727 0.516899 0.593106
5 2 0.212854 0.53248 0.455062
6 4 0.340533 0.604208 0.576837
Where did I do wrong? in the data file or input file? Thanks
jing
