Help with fix bond/react
I am trying to run coarse-grained simulation of a catalytic bond breaking event. The reaction template involves a fragments of a polymer chain (atoms 1-2-3-4) and a catalytic molecule (5-6). I set atom 1 as the edge atom as it is connected to the rest of the polymer chain. But when I ran the simulations, I kept getting the following error message:
Fix bond/react: Excessive iteration of superimpose algorithm. Please check that all pre-reaction template atoms are linked to an initiator atom, via at least one path that does not involve edge atoms. (src/REACTION/fix_bond_react.cpp:1450
Here I attach my template files:
Before reaction:
molecule template: chain end structures before rxn
    6  atoms
    4  bonds
    0  angles
    0  dihedrals
Coords
    1    19.899810791    12.733695984    18.098842621
    2    18.919700623    13.421165466    17.828743744
    3    18.019700623    14.717165466    17.028743744
    4    17.519700623    15.421165466    16.528743744
    5    12.919700623    13.421165466    17.828743744
    6    14.019700623    13.021165466    17.728743744
Types
    1    1
    2    2
    3    2
    4    7
    5    4
    6    5
Charges
    1    0
    2    0
    3    0
    4    0
    5    0
    6    0
Molecules
    1    1
    2    1
    3    1
    4    1
    5    2
    6    2
Bonds
    1    1    1    2
    2    2    2    3
    3    5    3    4
    4    3    5    6
After reaction:
molecule template: chain end structures after rxn
    6  atoms
    3  bonds
    0  angles
    0  dihedrals
Coords
Types
    1    1
    2    2
    3    2
    4    8
    5    4
    6    5
Charges
    1    0
    2    0
    3    0
    4    0
    5    0
    6    0
Molecules
    1    1
    2    1
    3    1
    4    3
    5    2
    6    2
Bonds
    1    1    1    2
    2    2    2    3
    3    3    5    6
Map file:
map file
1 edgeIDs
6 equivalences
InitiatorIDs
4
5
EdgeIDs
1
Equivalences
1       1
2       2
3       3
4       4
5       5
6       6
From how I understand the algorithm, all the atoms should be connected to the initiator through a path that does not involve the edge atom, except for the edge atom itself. So I don’t understand why I am seeing this error. Any help is appreciated!
There was some version of this post that was deleted, do you still need help? If so, please post all the files necessary (including input file, data file) to run a short simulation to reproduce your issue.
Thank you for your response! Since I am a new user, the group does not allow me to post any files along with the reply. Is there an alternative way to share the files?
Yes, you can provide links to other file-hosting services.
Thank you! Please find the files at the following link: Dropbox
The runs include more reactions than I have shared above. The activation step and depolymerization steps have been tested separately without any issues. The error only popped up when I added the chain end cyclic structure detachment step, specifically the reaction with “Cyclic_detatch_middle_map” in the filename, and rxn4 in the bond/react fix in the input file.
BTW I am using LAMMPS (12 Jun 2025) version. Thank you so much for your help!
The input file you provided does not run. Can you provide a working example? It would also be very helpful to provide a much smaller example that reproduces your issue.
Sorry I forgot to provide a script to run with the input script. Please see the test.sh script that I just added to the dropbox folder which includes all the variables. It is a bit hard to create a smaller system at this point, since the initial condition was generated through a different equilibrium run. If this does not work, I can try to initiate a smaller system and update you with the new data file. Thank you so much for your help!
It looks like the issue is a typo in the input script for rxn5: you switched your pre- and post-reaction templates.
Ah thanks for pointing it out!! I did a test run and now it’s working fine. I thought it’s the problem with rxn4. Thank you for your help!
