I'm going to define a local electric field in LAMMPS .I'm still beginner and don't know how to that.I'm just going to define an electric field with this components for now : (x,0,0) which the x component of field is depends on the location:
I've read the efield section of the manual but I think I'm making a mistake.
variable x
fix h a efield x 0.0 0.0
Ata Madanchi
________________________________
To: [email protected]
Subject: Help with Local Electric field
Date: Sat, 12 Mar 2016 10:07:52 +0330
what do you mean by "local" electric field?
please note what fix efield does is essentially a statically added
force that is scaled by the atomic charge of the affected particle.
the location:
yes, the following has *two* mistakes. both the variable command and
the fix efield command are use incorrectly and in disagreement what
the respective documentation says.
