Dear all
I am simulating a binary Lennard Jones system with 1024 particle and 1.2 density in reduced unit.input file is like that
3d Lennard-Jones melt
variable x index 1
variable y index 1
variable z index 1
variable xx equal 8*$x
variable yy equal 8*$y
variable zz equal 8*$z
units lj
atom_style atomic
lattice bcc 1.2
region box block 0 {xx} 0 {yy} 0 ${zz}
create_box 1 box
create_atoms 1 box
#read_data initdat.dat
#read_restart restart4.dat
mass 1 1
velocity all create 1.2 11152 mom yes rot yes dist gaussian
pair_style lj/cut 2.5
pair_coeff 1 1 1.0 1.0 2.5
#pair_coeff 1 2 1.5 0.8 2.5
#pair_coeff 2 2 0.5 0.88 2.5
neighbor 0.3 bin
neigh_modify delay 0 every 20 check no
fix 1 all nvt temp 1.2 1.2 100.0
thermo_style custom step temp press pe ke etotal vol enthalpy
thermo 100
thermo_modify flush yes
dump 2 all custom 10 dump.xyz id type xu yu zu
dump_modify 2 sort 1
restart 1000 restart5.dat restart6.dat
run 200000
when density is 0.8442 i am getting a correct dump file from where i am getting correct msd & vanhove correlation function.But in case of density 1.2 i am getting wrong result from simulation.
Would you have any clue regarding this?
