How can I achieve my idea with ReaxFF forcefiled in lammps
If you are using reaxff, you will get interactions between all atoms as defined by the fundamental bond length/ bond order relationship used. In addition, nonbonded interactions (van der Waals, Coulomb) are calculated between every atom pair, irrespective of connectivity. Excessive close-range nonbonded interactions are avoided by shielding.
So, all the interactions in your carbon cluster are intrinsic to your calculation using reaxff.
Here’s a good primer:
http://www.wag.caltech.edu/home/duin/Reax/ch121ReaxFF_introduction.pdf
The good reaxff stuff starts on page 16 and following.
Jim
James Kress Ph.D., President
The KressWorks® Foundation
An IRS Approved 501 ©(3) Charitable, Nonprofit Organization
Engineering The Cure” ©
(248) 605-8770
Learn More and Donate At:
Website: http://www.kressworks.org
Facebook: https://www.facebook.com/KressWorks.Foundation/
Twitter: @KressWorksFnd
Confidentiality Notice | This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain confidential or proprietary information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, immediately contact the sender by reply e-mail and destroy all copies of the original message.
