Hello. all users.! Always thank you for your kindness!
I'm calculating the thermal conductivity of silicon by EMD green-kubo method using fix ave/corr command.
And here is the question.
In some papers such as The Journal of Chemical Physics 143, 154703 (2015), or Nano Lett. 2017, 17, 1269−1276,
they plot the thermal conductivity in terms of correlation time.
Can I get such plot of thermal conductivity from J0Jt.dat file? (I set the fix _ave/corr command to defalut value.)
Give me a hand!
No, that is simply a plot of kappa as a function of the correlation time, ie. the evolution of a time-integral with increasing values of t.
Just perform step-wise numerical integration of the data contained in the J0Jt.dat file, multiply that by the appropriate scaling factor from the Green-Kubo formula, and you’re all set.
First of all, thank you and Thank you for your kindness!!
It would be very helpful to me!
Sorry, but I want to ask two more question!
1.
Then, I would like to know if there is command in LAMMPS which performs to plot J0Jt .dat file in terms of the evolution of a time-integral with increasing values of time t ,
or if I have to plot by using another tools like Gnuplot, Origin, etc..??
2.
If I have to use multiple fix ave/correlate command, does it take more time to finish the calculation?
How can I solve this problem?
Sorry, and Thank you your interest!!
Thank you!
1.
I may be wrong, but I don’t think that lammps can generate images of plots.
2.
It *will* be more compute intensive - but the additional overhead could be negligible. Just run some tests.
