I am calculating a cubic (fcc) ternary alloy with the command mmaps -d. However, when I use mapsrep, I obtain:
Maps version 3.08
Not enough known energies to fit CE
cat: clusters.out: No such file or directory
grep: predstr.out: No such file or directory
"mapsrep.gnu", line 7: warning: Skipping unreadable file "predstr.out"
"mapsrep.gnu", line 7: warning: Skipping unreadable file "fit.out"
"mapsrep.gnu", line 7: warning: Skipping unreadable file "gs.out"
How could I generate the predstr.out and clusters.out files?
PD: Please, mmaps have calculated 50 DFT structures, but I don’t have CE results.
Thank you,
Rafael Gonzalez-Hernandez
Barranquilla, Colombia, South America
Sorry for the delay (busy time).
I don’t see */str.out files. If these are absent, maps won’t recognize these as structure directories.
(BTW, when you send a file, make sure the extension matches the format. Your file was a .gz not a .bz2)
