Dear LAMMPS developers,
At the cutoff, are the LJ and Coulomb potential by default shifted to zero by subtracting the value at the cut-off to ensure that the energy is the integral of the force? or there are small forces at the cut-off?
Jibao
no. that statement is not correct. by default both are truncated.
the shifting of the potential only affects energies, *not* forces.
even with a shifted potential, you have a discontinuity in the forces.
however, that one is usually very small for typical LJ (4*sigma)
cutoffs and with long-range electrostatics, coulomb interactions are
almost exact.
if you want smooth truncation of forces without a long-range solver,
you need to use a pair style that does that, e.g. the charmm variants.
