Hi lammps users
After read the Pseudo-code in developer guide which explains how the Verlet:run () method works. I have a question about how lammps calculates the force when fix setforce command is used. As stated in developer guide, the MD force is computed by the methods from pair->compute () to kspace->compute (). While the fix->post_force () method deals with the external force. If the following command is used
fix 2 flexible_wall setforce 0.0 NULL NULL
I think lammps will set the force in x direction as 0. While the force components in y,z direction should same as the MD force which is calculated by the methods from pair->compute () to kspace->compute ().
Is that right?
Fan Li
