How to add
Hi All,
I have a question to make sure if my model is correct. I am modelling water evaporation. I want to define a zone on top of my box with p p f boundary conditions. I have defined a region on top of the simulation box called Eva, where all the atoms will be deleted if they reach into this region.
I have defined a reflecting wall on top of the box by fix wall/reflect. My question is can I define a reflecting wall on top of the simulation box, while I want to define the deleted zone there?
Atefeh
variable Ts equal 300.0
variable Ts_end equal 380.0
variable dt equal 0.001
variable Tdamp equal 100000dt #10dt
----------------- Initialize Simulation ---------------------
boundary p p f
processors * * 1
atom_style full
read_data data.data
pair_style hybrid eam/alloy lj/class2/coul/long 10.0 morse 9.8
pair_modify mix sixthpower
kspace_style pppm 0.00001
kspace_modify slab 5
kspace_modify order 7
pair_coeff * * eam/alloy Pt.lammps.eam_alloy.txt NULL NULL Pt
pair_coeff 1 1 lj/class2/coul/long 0.00055966 1.098 #H1-H1
pair_coeff 2 2 lj/class2/coul/long 0.01187722 3.608 #O1-O1
pair_coeff 1 3 morse 0.059 1.61 3.054
pair_coeff 2 3 morse 0.1084 2.411 2.416
bond_style class2
bond_coeff 1 0.970 24.43149365 -61.94706171 82.50182428 #H1-O1
angle_style class2
angle_coeff 1 103.700 2.161747342 -0.503133971 -0.346988942 # H1-O1-H1
angle_coeff 1 bb -0.412054554 0 0
angle_coeff 1 ba 0.969402954 0.969402954 0 0
group solid type 3
group water type 1 2
region fixed block EDGE EDGE EDGE EDGE EDGE 1 units box
region phan block EDGE EDGE EDGE EDGE 1 13.59 units box
region Eve block EDGE EDGE EDGE EDGE 200 EDGE units box
group fixed region fixed # fixed atoms at the bottom
group phan region phan # phantom atoms that control temperature
group surf subtract solid fixed # surface atoms, wall atoms excluding fixed atoms
#group free subtract surf phan # free atoms, thermal conduction layer
neighbor 0.3 bin
neigh_modify delay 0 every 1 check yes exclude group fixed fixed
---------- Run Minimization ---------------------
fix freeze fixed setforce 0 0 0
velocity phan set 0 0 0
fix top_wall all wall/reflect zhi EDGE units box
fix loadbalance all balance 100000 1.0 shift xy 10 1.1 weight time 0.8 out balance.output
thermo 1000
thermo_style custom step temp press etotal density
min_style cg
minimize 1e-6 1e-8 5000 10000
write_data data.system_min
reset_timestep 0
---------- Run Equilibration ---------------------
velocity all create ${Ts} 13425 mom yes rot yes dist gaussian
velocity fixed set 0.0 0.0 0.0 sum no units box
velocity phan set 0.0 0.0 0.0 sum no units box
fix 1 all nvt temp 300 300 ${Tdamp}
#fix 1 water nve
#fix 2 water temp/berendsen {Ts} {Ts} ${Tdamp}
#fix 3 phan nve
#fix 4 phan temp/berendsen {Ts} {Ts} ${Tdamp}
thermo 1000
dump 1 all xyz 1000 dumpnew.xyz
timestep ${dt}
run 15000
#write_data data.system_equil
#write_restart restart.equil
reset_timestep 0
----------------- Main NEMD simulation: Temperature ramp in the phantom layers -----------------
unfix 1
#unfix 2
#unfix 4
fix 5 all nve
fix tempramp phan nvt temp {Ts_end} {Ts_end} ${Tdamp}
fix 6 water evaporate 10 30 Eve 38277 molecule yes
thermo 100
----------------- Main NEMD simulation: run -----------------
dump 2 all xyz 100 dumpnew2.xyz
dump mydump2 all custom 100 run.*.lammpstrj id type x y z vx vy vz
dump_modify mydump2 sort id
restart 3400 restart.*.run
run 3400
Hi Atefeh
Would you please let me know why you want to delete those molecules???
Alireza Shadloo Jahromi
Ph.D. Candidate in Mechanical Engineering
Shiraz University of Technology.
