how to array an region along the x direction
Dear Sir or Madam,
I want to create many regions of the same size along the x direction, the distances between neighbour region are equal. So, how to array an region along the x direction.I don’t know which command can I use to achieve my purpose.
Best regards
Liang
Dear Sir or Madam,
what do you want to use those regions for?
if it is for binning purposes, you can using compute chunk/atom and then the corresponding fix xxx/chunk to collect the data.
otherwise, you would have to use variables and a loop. details on how to program loops and using variables are in the LAMMPS manual.
