Dear all
I have a GPU node with Maxwell GPU card(nvidia geforce 980), and I want to build LAMMPS on it with gpu package. I can build LAMMPS(latest stable version) with cuda package at this node and it works perfectly. How to modify the makefile in lib/gpu folder? An example is best.
What’s more, if in a node there are two GPUs, one GPU is geforce 780Ti and one is geforce 980, is this feasible ?
You can checkout README in lib/gpu to build libgpu.a.
lib/gpu/Makefile.linux can be a good example to start with. Generally, you may need to modify a couple of parameters such as CUDA_HOME to point to your CUDA install path, CUDA_ARCH to match the (common) compute capability of your card(s), etc.
The GPU package should work with the 2 GPUs, as you described, as long as the number of MPI tasks per GPU is greater than, or equal to, 1. The documentation explains this. (http://lammps.sandia.gov/doc/package.html and http://lammps.sandia.gov/doc/accelerate_gpu.html)
Hope it helps,
-Trung
Dear all
What's more, if in a node there are two GPUs, one GPU is geforce 780Ti and
please note that using two GPU models may lead to unexpected load
balancing problems, if the performance of the two GPUs is too
different.
Dear Dr. Axel Kohlmeyer:<br/><br/>Thanks very much for your advice. The problem has been solved.<br/><br/>Thanks
The problem has been solved. After update cuda driver, GPU package works all right.
Thanks for your reply.
