Dear Axel
I could not find any way to adjust the cutoff of ewald sum. In “kspace_modify” it is written: “The cutoff/adjust keyword applies only to MSM”.
Does the cutoff of ewald is the one in “pair_style” command?
sorry to bother you with this awkward question.
Regards
Sent with Mailtrack
If you read the manual carefully, it is the keyword “cutoff/adjust” being discussed there, not “cutoff”.
You should read the documentation a bit more thoroughly and realize that by yourself. Right now, it looks like you are reading only one sentence from each webpage, and then asking others to summarize the rest.
Giacomo
