how to control alpha parameter
Dear All,
I am trying to do a static tensile simulation of amorphous PMMA with minimize command. However, my minimizer can’t convergence to the tolerance and terminated with criterion for minimization is “line search alpha is zero”. My output file is as follow.
min_style cg
minimize 0.0 1.0e-3 10000 10000
Minimization stats:
Stopping criterion = linesearch alpha is zero
Energy initial, next-to-last, final =
-768453.22238 -768456.813894 -768456.813098
Force two-norm initial, final = 13456.8 657.938
Force max component initial, final = 9833.46 532.626
Final line search alpha, max atom move = 2.23823e-14 1.19214e-11
Iterations, force evaluations = 7 38
The alpha parameter is internal to the minimizizer
algorithm. You can’t “control” it. All the options
for controlling the minimizer are described in
the minimize and min_style and min_modify doc
pages.
The minimize doc page gives reasons why different models
and pair styles may be problematic when using
them for minimization. The alpha message is typically
a sympton of another problem - it’s not the problem
itself.
