Dear All,
I use
fix 2 all nve
fix 3 all temp/berendsen 4000 0 100
run 2000000
to simulate a cooling process with lammps. A I know, the cooling rate depends how long the time I run the simulation.
Thus, if the temperature decreases from 4000k to 0K in 400ps, the fooling rate will be 40K/ps, while running in 2000ps, the cooling rate would be 2k/ps, right?
But, from the output file, I found that after 400ps, the temperature just decreased to 2000K, not 0K. It means the cooling process did not finish.
So, how to adjust the parameters to sun an overall cooling process, especially in a short time?
Regards
Yanan Lv
Institute for Frontier Materials
Geelong Warunponds Campus
Victoria 3217 Australia
: E-mail: [email protected]…3412…
Website: http://www.deakin.edu.au
Deakin University CRICOS Provider Code 00113B (Vic)
Dear All,
I use
fix 2 all nve
run 2000000
2k/ps, right?
no. you are discounting the fact, that the berendsen
thermostat is approximating the temperature decrease
with an exponential decay using a time constant
(100 in your case). the smaller this time constant,
the closer the cooling is to your desired linear
temperature decrease.
are you by any chance running in metal units?
then the 100 of the berendsen time constant would be
100ps, which is fairly long considering your total
simulation time and would explain the behavior you see.
