Hi everyone
I came across a problem on creating a moving spherical reflect wall in LAMMPS. There is a hallow spherical structure with a diameter of 10 nm in my simulation, I want to avoid particles outside this structure come into the hallow holes, so I want to add one spherical reflect wall around this hallow spherical structure. I knew fix wall/reflect plus proper variable can achieve this. But actually, this structure is not stationary, its positions changes with external environment, so I don’t know how to make it. Can any one give me some suggestions? I would really appreciate it.
Best regards
Hi everyone
It is unlikely that fix wall/reflect, which operates on planes, can
achieve this.
changes with external environment, so I don't know how to make it. Can any
How are you going to change the position of a hollow sphere?
Equal-style variable?
Try fix indent.
Ray
Hi everyone
You need a text editor and start programming.
Axel.
You might be able to use fix wall/region with a spherical
region, and use the optional move keyword on the region
command to move the center of the sphere over time.
