I want to run two gcmc simulations in two boxes in an input. So, I need to create two boxes. But, lammps seems not support peration like this. I get back error “Cannot create_box after simulation box is defined”. So, anyone have good advices? By the way, whether lammps simulate two gcmc in an input, like this: fix gcmc1… \t fix gcmc2… \t run 1000 ? Many thanks!
this is a very unusual request. but it is possible to run two simulations at the same time using the -p / -partition flag and then run multiple “worlds” using “universe” or “world” style variables to apply different settings to each partition.
yes, and deservedly so.
have you read the fix gcmc documentation? if not, please do it thoroughly.
If what you are asking is to couple (in an MC sense) the 2 boxes,
as in a Gibbs ensemble, then you would probably be better off writing
a small Python or C driver program which instantiated LAMMPS twice
thru its library interface. The 2 intstances of LAMMPS would run independently
and the driver program could pass information back and forth
between them according to MC or Gibbs rules.
If you simple want to run 2 independent simulations (GCMC or otherwise),
then do what Axel said. Or see section Howto 8.2.3 of the manual.
You can run N simualtions that way.
