Hi LAMMPS users
I am new to the LAMMPS. I am trying to find tabular SiC.tersoff potential (like what we have on http://www.ctcms.nist.gov/potentials/). But it seems like it doesn’t have all interatomic potentials. Is there any other source where I can find it or should I code it myself (based on papers in the literature)?
Thanks in advance,
Hi LAMMPS users
LAMMPS does ship with a variety of SiC.tersoff potential files.
those are EAM potentials.
Thanks for your response. But I dont understand, what do you mean the LAMMPS is shipped with SiC.tersoff potential files.
I am using windows executable LAMMPS, and I dont know where are these files are. When I try to execute the following code, it shoots out: Error: cannot open tersoff potential file SiC.tersoff
Find minimum energy of graphene with hexagonal configuration
Ali Nafari, 2013
--------------------- Initialize Simulation ---------------------
clear
atom_style atomic
newton on
############# processors 2 2 1
------------------------- 2D Simulation -------------------------
dimension 2
read_data Graphene.txt
----------------------Interatomic Potential ---------------------
pair_style tersoff
pair_coeff * * SiC.tersoff C
------------------------- Define Settings -----------------------
neighbor 2.0 bin
neigh_modify delay 3
timestep 0.001
thermo_style custom step pe etotal
thermo 10
restart 50000 NICYCLESTAT.STA
Dump Graphene all xyz 100 Graphene.xyz
--------------------------- Delete Atoms ------------------------
############# region del block 10 15 10 15 0 0 units box
############# delete_atoms porosity del 0.1 12345
---------------------------- Relaxation -------------------------
min_style cg
minimize 1e-4 1e-6 1000 100000
----------------------------- Dynamics --------------------------
fix frelax all nve
fix controltemp all temp/rescale 100 10.0 10.0 10.0 1.0
run 1000
unfix controltemp
unfix frelax
undump Graphene
print “All done!”
the lammps distribution has them.
this is just a pre-compiled executable and the download page on the
lammps homepage specifically explains that you *also* have to download
the source packages to get the rest. reading helps.
if you download the an installer package from here:
http://git.icms.temple.edu/rpm/windows.html
it will not only bundle the potentials, documentation, benchmarks and
most examples, but also have it preconfigured that it should
automatically pick up any potential file that is shipped with LAMMPS
without having to copy it or specify the path though configuring the
environment variable LAMMPS_POTENTIALS during installation.
