How to find test_pair_style
After i builded Lammps by Cmake with command “-D ENABLE_TESTING=on”, i can not find test_pair_style under ./build or ./build/unittest/force-styles. Expecting for your help, thanks.
What are the exact steps you performed? What was the output produced? Were there any errors?
Please also provide details about your LAMMPS version and platform and so on as outlined in the forum guidelines.
LAMMPS version: Large-scale Atomic/Molecular Massively Parallel Simulator - 15 Jun 2023 - Development
Git info (release / patch_28Mar2023_update1-modified)
Cmake command:
mkdir build; cd build
cmake …/cmake -D ENABLE_TESTING=on -D PKG_MANYBODY=yes -D PKG_MOLECULE=yes -D PKG_KSPACE=yes -D BUILD_MPI=yes -D BUILD_OMP=no -D PKG_REPLICA=yes -D PKG_RIGID=yes
make
Command line:
lammps2023/build/unittest/force-styles/test_pair_style lammps2023/unittest/force-styles/tests/kspace-pppm_dipole.yaml
Output:
execvp error on file /lammps2023/build/unittest/force-styles/test_pair_style (No such file or directory)
Thanks for your help. I purged all settings, and maked again. It works!. The problem is solved.
