Hellow lammps users,
I want to fix an atom during some time setups, and then unfix it.
fix
velocity pointfixed set 0.0 0.0 0.0
fix 1 pointfixed setforce 0.0 0.0 0.0
run 10000
unfix
velocity pointfixed set NULL NULL NULL
unfix 1
run 10000
The fix part works but unfix part can’t work, so would you have other solutions for fixing and unfixing an atom?
Meng LIAO
## fix
run 10000
## unfix
unfix 1
run 10000
The fix part works but unfix part can't work, so would you have other
the unfix *definitely* works. however, your second velocity command makes
no sense, as it doesn't do anything.
there is not enough information there to explain why you don't get what you
expect.
system
March 29, 2016, 12:21pm
#3
I also want to unlock the atom’s velocity, how can I set the atom free?
Re: [lammps-users] How to fix and unfix an atom?
I also want to unlock the atom's velocity, how can I set the atom free?
you have erased it. it is gone. you have to assign a new velocity.
… or follow a different strategy to immobilize your atom: do not include it in time integration.
this way, it will retain its velocity, you compute its forces, but don’t update either position or velocity.
You could also try the fix martin/luther/king command ...
You could also try the fix martin/luther/king command …
Really, just silence from the mail list? This was my best joke in months …
it is *too* good. how can one top this?
