Dear All
I am a new in MD simulation and new user of LAMMPS. I am trying to do a simulation for graphene and CO2 system for practice. However, when I run simulation without fixing or making rigid the structure of the graphene I can found some of the CO2 molecules are adsorbed on graphene. But when I use
fix 1 all nvt temp 273.0 273.0 100.0
fix 2 graphene1 setforce 0.0 0.0 0.0
fix 3 graphene2 setforce 0.0 0.0 0.0
comments for fix the graphene in a position, then I could not found any kinds of adsorption phenomenon. What kinds of mistake I made? could anyone please help me?
Thanks in advance
please see my recommendation to a similar question posted yesterday.
please also understand, that this mailing list is not intended to be a classroom for learning MD.
Dear Axel
Thank you for your suggestion.
Certainly, its not a class room for a expart but as undergraduate student I suppose it is more than class room for me to learn LAMMPS!!
However, I am stragglin to sort out that why when I use " set force " coomand the intarection is missing, is it not possible to calculate the interaction if I use set force command ?
Thank you
Dear Axel
http://lammps.sandia.gov/guidelines.html
The fix setforce doc page explains that it outputs the force on its atoms
before it reset them to zero (or whatever).
