How to Make a Particle self propelled in LAMMPS
I want to simulate self propelled particle in LAMMPS. But I don’t have much idea about LAMMPS and want to know in what way I can make the Particle Self Propelled in LAMMPS?
Thanks in Advance
-Ligesh
A while back I wrote a fix for this that got the job done but it wasn’t polished enough for inclusion in lammps at the time and then I moved on to other things. I can dig it up for you later today.
Conceptually, the fix just applied a constant force along a per-particle vector so that, combined with fix langevin, it would move like an active Brownian particle.
Thank You all… I will check with your suggestions…
I filed a pull request with a slightly cleaned-up version of my old code here: https://github.com/lammps/lammps/pull/1178/files
