Hi everyone,
In my research, i usually use “fix reaxc/c/species” command to output the resultant. But rescently i am calculating the Pd catalyst. So the “fix reaxc/c/species” command can not be used anymore. I want to output the resultant,so i am wondering how can i deal with the “fix reax/c/bond” to output the resultant i need. Should i write a script using perl? Or is there any script already existed? Thanks a lot.
Danny bootman
Best wishes
