Dear Alex,
I have a question related to the restart of the calculation, Can I restart the amset calculation when it stops at some point or I need the start it scratch?
Hi Aamir,
Currently there isn’t a way to restart an amset calculation. I can look at adding this feature in the future but as it stands it is not on the road map.
If amset is running slowly for your, can I double check you are:
- Using the
nworkers
setting in the settings.yaml - Including
export OMP_NUM_THREADS=1
in your job script before callingamset run
. This can often increase the speed of amset by 3-4 times.
Alex
