How to see codes beneath Lammps commands
Dear Users,
I need to check what is happening beneath a Lammps code? How can I see the basic codes that are written to perform a single lammps command?
Neda
Dear Users,
​please study the available documentation and learn what the basic flow of
control is. you can start here.​
​axel.​
Also, nearly every “single command” you use in your
input script, has a corresponding source file with
the code that “performs the command”.
E.g. run -> run.cpp, fix nve -> fix_nve.cpp, etc
