Good day lammps-users,
I just want to ask how to specify Cu(111) surface as the deposition region for graphene.
By searching here on the lammps-users mailing list, I found one answer indicating this orientation of the lattice. But I’m assuming the plane along the z-axis is not the FCC(111) surface in which I want to deposit.
lattice fcc 3.61 orient x 1 1 1 orient y 1 -1 0 orient z 1 1 -2
I just want to ask how to indicate the proper orientation of the lattice to specify the Cu(111) surface as the deposition region or the top surface in which I will deposit graphene. Thank you.
