I need to calculate the mass density of water in CNT. The radius of CNT is 5.45 Angs and the height of tube changes between 32-58.26 Angs. Based on these dimensions, I set the coordinates of the computational domain with real units in the input file as:
-6.5 6.5 xlo xhi
-6.5 6.5 ylo yhi
31.0 58.8 zlo zhi
To calculate the density of water, I used the following command:
compute cc1 mobile chunk/atom bin/cylinder z lower 26.26 0 0 0.0 5.4 30 units box
fix 1 mobile ave/chunk 1 20000 20000 cc1 vx vy vz density/number density/mass file vel1.profile
In the output file, I get the following numbers:
Chunk Coord1 Coord2 Ncount vx vy vz density/number density/mass
40000 60 231
1 0.09 44.13 9.34205 -4.33601e-05 -5.36655e-05 6.57059e-06 3.49504 71.2459
2 0.09 70.39 0.10235 -0.000372728 -0.000419092 -0.000203393 0.0382911 1.01591
3 0.27 44.13 5.735 3.71229e-05 -3.98979e-05 2.37601e-05 0.715192 8.56079
4 0.27 70.39 0.15325 -0.000426444 -1.19502e-05 2.08448e-05 0.0191113 0.471264
5 0.45 44.13 2.1103 3.9363e-05 0.00031698 -0.000120481 0.157901 0.672219
My question is that what are those two numbers as Corrd2 (44.13 and 70.39)? Do they represent two sections at the entrance and exit of tube? If so, I didn’t apply this in the command of chunk/atom. I just divided the tube in radial direction and why these two numbers are not same as what I applied as the height of tube (32 to 58.26)?
To get the right density at each radial section, do I need to get average between densities at two heights?
E.g. at radius=0.09: Mass Density=0.5 *(71.2459+1.01591)=36.13.
Thanks and regards,
Hamed.
