hi
dear all
i have a mulecule which i want to take it as a rigid bodey i used the fix
rigid command to do so but when i runed the system my molecule is both
rigid and fixed in it's initial coordiates. i want it to move as a rigid
bodey.how can i do that ?
thanks
hi
dear all
impossible to say without any information about what you did.
the fix rigid documentation contains explanations for how to use it and
the examples/rigid directory contains examples. they all work, so you must
be doing something wrong.
fix 3 c60 rigid/small molecule langevin 1.0 1.0 1.0 428984
> fix 1 all npt temp 300.0 300.0 100.0 iso 1 1 1000These lines are applying 2 thermostats and 2 time integrators to
the same particles. Which is bad. You should have got
a WARNING from LAMMPS that you are time integrating
twice. The fix rigid doc page has a section about how to do constant
pressure with rigid bodies. You need to follow what it says.
furthermore, the langevin thermostat is set to thermalize at 1K. not much
can happen at that temperature anyway.
GI-GO,
thanks Mr kohlmer
