hybrid airebo
Dear lammps community,
I'm trying to use AIREBO potential in hybrid style. This topic was recently discussed in the mail list, however, I tried to use as it was proposed there and it didn't work. The error message is "Pair coeff for hybrid has invalid style". I tried to substitute AIREBO by Tersoff potential, and it worked. So I conclude that the problem is with AIREBO. Does anyone know what can be the problem with hybrid airebo? Here is a part of my input file
pair_style hybrid airebo 3.0 1 0 lj/cut 2.5
pair_coeff * * CH.airebo C H NULL
pair_coeff 2 3 lj/cut 1.0 1.0 2.5
pair_coeff 1 3 lj/cut 1.0 1.0 2.5
I'm using the version of lammps of 18 January 2011.
Thanks for any advices!
Yury Fomin
i would suspect it is due to the optional arguments in the
airebo style definition. can you please leave them out and try again?
Dear Axel,
The coefficients at airebo potential I took from the previous discussion about hybrid/airebo and they work with pure airebo potential. Now I tried to run without these coefficients. If I use pure airebo
pair_style airebo 3.0
pair_coeff * * CH.airebo C C H
everything is ok. As soon as I try to do hybrid
pair_style hybrid airebo 3.0 lj/cut 2.5
#pair_style hybrid tersoff lj/cut 2.5
#pair_coeff * * tersoff Si.tersoff Si Si NULL
pair_coeff 3 3 lj/cut 1.0 1.0 2.5
I have the error message - "ERROR: Pair coeff for hybrid has invalid style". If I use hybrid tersoff instead of airebo, then it works. My conclusion from this is that something is wrong with my implementation of airebo in hybrid. But I could not identify the problem. Do you have any idea what can be wrong?
Thanks in advance!
Yury Fomin
This command needs to be:
pair_coeff * * airebo CH.airebo C H NULL
when in hybrid mode.
There's no way that mistake worked with Tersoff either.
