Stan Moore (Sandia) has done some nice work to clean up and fix bugs in some code for both short- and long-range dipole/dipole and charge/dipole interactions. Two new pair_styles were also added: pair_style lj/cut/dipole/long and lj/long/coul/long. Long-range dipole interactions can now be computed by kspace_style ewald/disp. All of the options are described in the pertinent pair_style and kspace_style doc pages.
BACKWARD COMPATIBILITY: The names of two of the previous dipole pair styles were changed to be more compatible with the LAMMPS naming conventions. Specifically, dipole/cut was changed to lj/cut/dipole/cut, and dipole/sf was changed to lj/cut/dipole/sf.
You are using the pair style name that was changed between the two releases.
