Hey All,
I’m getting an invalid pair style error on a Bluegene system, when I run the same input script on my Windows 7 system it works. I have two atom types and I’m using a hybrid lj/class2 airebo potential on my system (some atoms interact with AIREBO, some with LJ). My pair style definition is as follows:
pair_style hybrid lj/class2 5.0 airebo 3.0
pair_coeff * 2 lj/class2 $r 2.0
pair_coeff * * airebo CH.airebo C NULL
Is there any way to check if lj/class2 is available on the Bluegene build?
-Emil
Hey All,
follows:
try:
strings /path/to/lmp_bgl | grep class2
i get on my machine:
[[email protected]... ~]$ strings ~/compile/lammps-ro/src/lmp_fftw3 | grep class2
lj_class2_long
lj/class2/coul/cut
lj/class2/coul/long/gpu
lj/class2/coul/long
lj/class2/gpu
lj/class2
Pair style lj/class2/coul/cut requires atom attribute q
Pair style lj/class2/coul/long requires atom attribute q
Pair style lj/class2/coul/long/gpu requires atom attribute q
Cannot use newton pair with lj/class2/coul/long/gpu pair style
Cannot use newton pair with lj/class2/gpu pair style
HTH,
Try the latest 20Aug11 patch, and after you build
LAMMPS, type
lmp_foo -h
This will list all the style options compiled into that executable
and exit.
