I am getting error while running NEB calculations for Vacancy Migration Energy
Can Anyone help me out with correcting this lammps script where i am using kim potential
%%writefile W_bcc_neb.in
NEB simulation of vacancy hopping in silicon crystal
kim init SNAP_LiChenZheng_2019_NbTaWMo__MO_560387080449_000 metal
atom_style atomic
atom_modify map array
atom_modify sort 0 0.0
coordination number cutoff
#variable r equal 2.835
diamond unit cell
#create_box 1 myreg
#create_atoms 1 region myreg
#mass 1 28.06
#write_data initial.sivac
read_data initial.lmp
make a vacancy
#group W type 1
#group del id 300
#delete_atoms group del compress no
#group vacneigh id 174 175 301 304 306 331 337
choose potential
kim interactions W
mass 1 183.84
set up neb run
variable u uloop 20
initial minimization to relax vacancy
displace_atoms all random 0.1 0.1 0.1 123456
minimize 1.0e-6 1.0e-4 1000 10000
reset_timestep 0
only output atoms near vacancy
dump events vacneigh custom 1000 dump.neb.sivac.$u id type x y z
fix 1 all neb 1.0
thermo 100
run NEB for 2000 steps or to force tolerance
timestep 0.01
min_style quickmin
neb 0.0 0.01 100 100 10 final final.lmp
the following is the error
LAMMPS (7 Feb 2024)
Running on 4 partitions of processors
Reading NEB coordinate file(s) …
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Not unless you change your post so that it is properly readable. Please see the forum guidelines about how to quote text in this forum.
