i have an error message for cygwin installation
Dear all:
last time i have asked about the problem rencontred with windows exe version during the test of reax example and later i have learned in the lammps site that the windows exe version distributed by the lammps staff don’t execute all lammps abilities.
i have tried to run lammps on cygwin 1 proc machine, based on the notes giving in the manual and the make_serial example, i have edited the makefile and than i have run the installation procedure.
the procedure start without any problem but after a giving times the installation stop and i have the message showed in the attaced file
i note that i have used the FFT and not FFTW2 or 3
so if any one have an idea about this problem send me a message please.
best regards
lammpserror.rtf (6.16 MB)
Dear all:
that the windows exe version distributed by the lammps staff don't execute
best regards
two comments:
a) lammps output is in text format. please cut and paste the text.
no need to create a wordprocessor file from it. this just causes a
lot of effort to read for no good reason. if you rather like to send
a screenshot, then make it a .jpg file. the simpler you make it to
look at what you have to report, the more likely you are to get help.
b) you are linking code compiled with g++ not with g++ bug gcc.
this cannot work. c++ code requires special treatment at the
linkage stage, so you have to use the c++ compiler variant to link.
