Title: I need some clarifications on the Coulomb interaction in Lammps.
For pair potentials such as Born?CMayer?CHuggins, there is an adding Coulombic pairwise interaction which is expressed as: (Page 1103 in the latest Manual).
C is an energy-conversion constant. However, in some references(Masahiko Matsumiya, Ryuzo Takagi, Electrochimica Acta 46 (2001) 3563?C3572), the Coulombic interaction is:
Otherwise, some other references (Jamshed Anwar et al, J. Chem. Phys., Vol. 118, No. 2, 8 January 2003) formulate the Coulombic interaction as: .
My questions:
What is the energy-conversion constant means? What is the value and unit of it? Does it have any relationships with the electrostatic constant?
Why the energy-conversion constant is ignored sometimes? Should I modify the energy-conversion constant to satisfy the references’ expressions? If so, how to modify the energy-conversion constant.
Does the charge numbers are always integers? E.g. the charge of Na+ in NaCl is +1 with enough precision?
Thank you very much!
For pair potentials such as Born–Mayer–Huggins, there is an adding
latest Manual).
Matsumiya, Ryuzo Takagi, Electrochimica Acta 46 (2001) 3563–3572), the
My questions:
1. What is the energy-conversion constant means? What is the value
constant?
it is essentially a unit conversion factor. its value depends on what unit
of energy and what units of charge you have.
2. Why the energy-conversion constant is ignored sometimes? Should I
see answer to question 1.
3. Does the charge numbers are always integers? E.g. the charge of
no. that is model dependent, but for salts it is often chosen to be
integers.
