I tried to use pymatgen CifParser to parse cif downloaded from ICSD, and output the bibtex from cifparser. But it seems like all the ICSD cifs do not work.
from pymatgen.io.cif import CifParser
icsd_fn = "YourCustomFileName1_CollCode2356.cif"
parser = CifParser(icsd_fn)
parser.get_bibtex_string()
The `get_bibtex_string()` function will give the following error:
TypeError Traceback (most recent call last)
~/anaconda/envs/strumining/lib/python3.6/site-packages/latexcodec/codec.py in encode(self, unicode_, errors)
804 return (
--> 805 encoder.encode(unicode_, final=True),
806 len(unicode_),
~/anaconda/envs/strumining/lib/python3.6/site-packages/latexcodec/lexer.py in encode(self, unicode_, final)
478 return self.emptychar.join(
--> 479 self.get_latex_bytes(unicode_, final=final))
480 except UnicodeEncodeError as e:
~/anaconda/envs/strumining/lib/python3.6/site-packages/latexcodec/codec.py in get_latex_bytes(self, unicode_, final)
725 "expected unicode for encode input, but got {0} instead"
--> 726 .format(unicode_.__class__.__name__))
727 # convert character by character
TypeError: expected unicode for encode input, but got list instead
The above exception was the direct cause of the following exception:
<ipython-input-53-e8cf025fac04> in <module>()
----> 1 parser.get_bibtex_string()
~/anaconda/envs/strumining/lib/python3.6/site-packages/monty/dev.py in decorated(*args, **kwargs)
90 if not self.condition:
91 raise RuntimeError(self.message)
---> 92 return _callable(*args, **kwargs)
93
94 return decorated
~/anaconda/envs/strumining/lib/python3.6/site-packages/pymatgen/io/cif.py in get_bibtex_string(self)
1123 entries['cif-reference-{}'.format(idx)] = Entry('article', list(bibtex_entry.items()))
1124
-> 1125 return BibliographyData(entries).to_string(bib_format='bibtex')
1126
1127 def as_dict(self):
~/anaconda/envs/strumining/lib/python3.6/site-packages/pybtex/database/__init__.py in to_string(self, bib_format, **kwargs)
284 """
285 writer = find_plugin('pybtex.database.output', bib_format)(**kwargs)
--> 286 return writer.to_string(self)
287
288 def to_bytes(self, bib_format, **kwargs):
~/anaconda/envs/strumining/lib/python3.6/site-packages/pybtex/database/output/__init__.py in to_string(self, bib_data)
51
52 def to_string(self, bib_data):
---> 53 result = self._to_string_or_bytes(bib_data)
54 return result if self.unicode_io else result.decode(self.encoding)
55
~/anaconda/envs/strumining/lib/python3.6/site-packages/pybtex/database/output/__init__.py in _to_string_or_bytes(self, bib_data)
47 def _to_string_or_bytes(self, bib_data):
48 stream = io.StringIO() if self.unicode_io else io.BytesIO()
---> 49 self.write_stream(bib_data, stream)
50 return stream.getvalue()
51
~/anaconda/envs/strumining/lib/python3.6/site-packages/pybtex/database/output/bibtex.py in write_stream(self, bib_data, stream)
167 self._write_persons(stream, persons, role)
168 for type, value in entry.fields.items():
--> 169 self._write_field(stream, type, value)
170 stream.write(u'\n}\n')
~/anaconda/envs/strumining/lib/python3.6/site-packages/pybtex/database/output/bibtex.py in _write_field(self, stream, type, value)
121
122 def _write_field(self, stream, type, value):
--> 123 stream.write(u',\n %s = %s' % (type, self.quote(self._encode(value))))
124
125 def _format_name(self, stream, person):
~/anaconda/envs/strumining/lib/python3.6/site-packages/pybtex/database/output/bibtex.py in _encode(self, text)
105 import latexcodec # NOQA
106
--> 107 return codecs.encode(text, 'ulatex+{}'.format(self.encoding))
108
109 def _encode_with_comments(self, text):
TypeError: encoding with 'ulatex+UTF-8' codec failed (TypeError: expected unicode for encode input, but got list instead)
Can anyone help with this? I tested cifs from other DBs, like from COD (Crystallography Open Database), the function works great. But all the cifs I got from ICSD do not work.
