Should i set if command in loop?
If i use conditional command lonely, it doesnt work?
Samira
Samira
nobody can advise anything else on "it doesn't work"
but "then you must be doing something wrong".
whenever you ask for help you need to explain:
- what it is you want to achieve,
- provide one or more examples of what you tried,
- explain what you expected
- and what you saw instead.
answers can only be as good as the question.
