Dear Axel and Steve
I’m making a data file using topotool, however, due to an unknown malfunction, an unrealistic bond appears in the data file.
I couldn’t fix that, so, I decided to set zero energy constant, i.e., Kb, for that bond (the bond style is harmonic).
Is it a correct? How can I ignore the effect of a redundant bond or angle without removing it?
Dear Axel and Steve
with topotools you can remove individual bonds.
Is it a correct?
no.
you cannot. the presence of the bond will alter the neighbor list due to causing excluded pairs and you cannot have different exclusions settings for different bonds.
you must prepare a correct data file.
