Hi community,
Below is my lammps input script. I am trying to do NEB on two configurations. The initial config with atom coords is being read using the read_data command and the final config is the coords.final file being read in the neb command in the last line of the script. The initial and the final config are both in the correct format. Also, please find attached the initial config(configforrunwithoutOatoms.txt) and the final config(coords.final). I am getting the illegal NEB command error in the last line. Could anybody please suggest what may be the issue…Any help will be helpful.
Name of the script - Example
atom_style atomic
#--------Reading Configuration----------
read_data configforrunwithoutOatoms.txt
#–Masses–##
mass 1 28.0855
mass 2 15.9994
#------interaction coefficients e,sigma,cutouff----------
pair_style tersoff
pair_coeff * * SiO.tersoff Si O
initial minimization to relax surface
#minimize 1.0e-6 1.0e-4 1000 10000
#reset_timestep 0
group moving id <> 1 408
group adatom id == 408
group fixed id <> 409 965
timestep 0.0005
neighbor 0.7 bin
fix 1 moving neb 1.0
#------output files-------------------------------
thermo_style custom step pe etotal
thermo 1
dump SilicaNEBdump all xyz 1 NEBDump.Startingxyz.xyz
#dump 1 nebatoms atom 10
min_style quickmin
neb 1.0e-5 1.0e-3 1000 1000 1 coords.final ERROR: Illegal NEB command
Regards,
Saketh.
configforrunwithoutOatoms.txt (28.9 KB)
coords.final (11.3 KB)
