I obtained the error message while trying to add “cluster yes” in the neigh_modify command. I didn’t see any restriction in the manual. Please kindly point out the error in the following input script. Thank you.
ERROR: Illegal neigh_modify command (neighbor.cpp:1729)
======input, comment line excluded========
units lj
atom_style angle
communicate single vel yes
pair_style dpd 1.0 1.0 34567
bond_style harmonic
neighbor 0.0 bin
neigh_modify delay 0 every 1 check no cluster yes
read_data data.c8e8r-4
velocity all create 1.0 34567
pair_coeff * * 106.5 1.5
pair_coeff 1 2 113.2 1.5
pair_coeff 1 3 126.5 1.5
pair_coeff 2 3 107.5 1.5
bond_coeff 1 40.0 0.8
bond_coeff 2 20.0 1.6
timestep 0.02
thermo_style multi
thermo 10
fix 1 all nve
group poly type 1 2
dump 1 poly xyz 1000 dump.c8e8r-4
write_restart restart.c8e8r-4.%.*
run 1000000
======End of input========================
